Page 1 of 2
AY_Emul (Новая версия плеера)
PostPosted: 12 May 2007, 09:35
by Bulba
Целых два дня ушло на то, чтобы залить AY-3-8910/12 Emulator v2.9 beta 2 на FTP нового хостинга, и всего восемь месяцев с момента выхода предыдущей версии smile
Кроме стандартного комплекта выложен архив TS-музыки в количестве 48 штук. Собственно для тех, кто следит за проектом, больше добавить нечего, а для остальных - список изменений.
28 September 2006
- Added tracker info during converting from PSM to VTX.
- Fixed some problems with folder browser.
06 January 2007
- Fixed Z80 emulation: OUT (c),0 command added.
29 April 2007
- Added 1.xx and 2.xx commands interpetation for PT 3.7+ modules.
1 May 2007
- One more standard STC string ID is added to STC title analizer.
7 May 2007
- AY emulation is redesigned to play Turbo Sound (2xAY) music.
- Any of two tracker modules (except FXM) can be played simultaneously now via special file format, which can be generated from Windows/DOS command line:
copy/b Module1.pt3+Module2.sqt+ID ModuleTS.pt3
where ID is 16 bytes length identificator file of next structure:
+0 Str4 'PT3!' (PT3 type marker)
+4 Word Module1FileSize
+6 Str4 'SQT!' (SQT type marker)
+A Word Module2FileSize
+C Str4 '02TS' (TS marker)
- New playlist version is designed to store info about TS modules.
8 May 2007
- Added support of PT 3.7+ modules saved in TS mode.
- Experemental code for standard open dialog is removed (see change at 18 September 2006) because not works in Win9x/Me/Vista. So, old problems come back (last masks in 'All Supported Types' filter are ignored). Will trying to wrote own Open Dialog.
9 May 2007
- All playlist operations like 'Convert to WAV...' work with all selected items now (specially for ASiC).
... Ay_Emul: scalesmann^mc. 2006 - panic (1st)
Re: AY_Emul (Новая версия плеера)
PostPosted: 14 May 2007, 12:18
by krb
таакс, сча посмотрим! (наконецто дорвался)
1 мин спустя:
ftp://ftp.untergrund.net/users/bulba/Ay_Emul29b2.7z << неработает линк
1мин спустя:
скачал с втрд
ещё чуть позже:
всё работает вроде нормально, но вот такая штука:
в ауемуле нажимаю на кнопку открыть файл, в появившемся опендиалоге выбираю рабочий стол, и ауемуль виснет почемуто :/ тоесть не реагирует ни на что, причем если в этот момент играла музыка - то она играет и дальше. может это от 2000й винды? попросил nq, он потестил у себя на хп профешнл версия 2002 сп 2 = на ней всё хорошо
есчо по тс - надо уменьшить громкости каждого трека, незнаю только насколько - тут надо експериментировать, так как иногда слышны перегрузки. особенно заметно в треке x-agona и в minik.
а вобще тс в ауэмуле - сдорово smile
PostPosted: 14 May 2007, 13:32
by Bulba
Quote (krb)
неработает линк
Блин, с этим Untergrund'ом столько проблем. Пару дней (9-10 мая) оказывается валялся один из зеркальных FTP, потому новая версия Ay_Emul была не доступна. Сейчас не работает вообще не один линк. Самое смешное, что пока писал bug-report админам, все заработало, что не пробую - все скачивается smile
Quote (krb)
Как раз в этой версии я убрал из Open Dialog'a все, что намудрил в предыдущей, глючить не должно. Может у тебя на столе какие-нибудь link-файлы лежат, типа "диск A:", которого нет, или на сетевеой ресурс, который отключен?
Quote (krb)
Так уменьшь wink В диалоге Mixer движок Preamp. Я уже по дефолту поставил 50% (что гарантирует отсутствие переполнения, можно процентов 70%, но тогда придется довериться теории вероятности). У тебя дефолтовая настройка видимо уже сбита предыдущей версией Ay_Emul 2.9 beta 1.
... Ay_Emul: Silent now...
PostPosted: 14 May 2007, 14:29
by krb
Quote (Bulba)
весь рабочий стол завален всевозможными линками/файлами, видимо из за этого..
почищю/потестю - расскажу как станет работать
Quote (Bulba)
Так уменьшь В диалоге Mixer движок Preamp.
гы, точна! crazy
PostPosted: 14 May 2007, 14:46
by krb
Quote (Bulba)
Quote (Bulba)
гы, точна! crazy
PostPosted: 18 May 2007, 21:04
by ch41ns4w
Заметил небольшой косяк...
Выбираю в плейлисте TS трек, жмакаю на Open in editor... И получаю только половину его sad
То есть, открывается только один модуль, а другой - йух.
PostPosted: 19 May 2007, 03:08
by Bulba
Это новый формат TS-треков, его будет понимать следующий VT, который уже почти готов (из запланированного осталось экспорт на ZX с новым TS-пллером доделать).
... Ay_Emul: no song playing...
PostPosted: 20 May 2007, 12:02
by C-jeff
Скачал новый AYEmul. Есть предложение ввести формат, скажем PTS, чтобы было видно, а не только слышно, что данный модуль - шестиканальный. А вообще, спасибо, наконец ТС можно слушать без проблем.
PostPosted: 20 May 2007, 12:18
by Bulba
Легко отвечать на письма, на которые уже отвечал wink Наверное ответ не дошел:
-----------start of цитата (13.05.2007)--------
DZ> Скачал новый AYEmul. Есть предложение ввести формат, ну
DZ> например PTS, чтобы было видно, а не только слышно, что этот
DZ> модуль - модуль под TS.
Формат уже есть, он и проигрывается в Ay_Emul, осталось еще в VT его
поддержать. О том, что играется TS, лучше юзеру не знать, итак уже под
AY никто почти не пишет, а тут и вообще интерес потеряют...
DZ> Ну и в редакторе его тоже поддержать smile А
DZ> вообще, спасибо, наконец ТС можно слушать без проблем.
wink
-----------end of цитата--------
PostPosted: 21 May 2007, 19:08
by krb
Quote (Bulba)
фигня это, от того, что появится pts - 100% никто писать не перестанет!
