Postby deathsoft » 24 Dec 2009, 19:14
Pentagon only popular as demo-scene computer. In St.Petersburg the most popular clone is scorpion.
Postby MKiller » 25 Dec 2009, 18:00
Pentago,Scorpion,ATM,Profi - some popular zx clone.
System die
MKiller
Postby VELESOFT » 01 Jan 2010, 17:26
My idea:
Each russian ZX clone use different paging ports, different ports adressations,etc...
On all new ZX clones will best way use one additional paging port with full 16bit adressation, readable state and same function. For example in PENTEVO and PENTAGON 2.666 implement paging port #FFDF (or any other) with this layout:
D0-D7 = set memory page number 0-255 = 4MB maximum.
On next additional port will possible set videoram and rom:
D0-videoram
D1-rom (48/128)
If this paging schematic will implemented in all new other clones, then can by some software compatible without modifications. State of this ports will readable, etc...
It's bad idea ?
SPRINTER 2000,ZX SPECTUM128+2,DATA-GER,K-MOUSE,DIVIDE512
VELESOFT
Postby deathsoft » 01 Jan 2010, 17:56
Pentevo use the same page mapping as ATM2 and extended page mapping where page number is 8bit (4Mb ram) (ports are the same as in ATM2, extended paging mode can be enabled via control port, please contact CHRV or LVD for details).
Postby VELESOFT » 01 Jan 2010, 18:45
deathsoft wrote:Pentevo use the same page mapping as ATM2 and extended page mapping where page number is 8bit (4Mb ram) (ports are the same as in ATM2, extended paging mode can be enabled via control port, please contact CHRV or LVD for details).
I will also soon write new firmware ( for my PROFI INTERFACE ) with emulation of ATM TURBO 2+ memory paging. Also on my SPRINTER 2000 computer is possible use TRDOS from ATM TURBO 2+ if will rewrited all paging ports. SPRINTER 2000 also use paging in any CPU area and set page 0-255 (4MB). Actually SPRINTER's trdos support only FDD and classic ramdisc via #3D13, but more next features as import / export TRD images from/to FAT16, DIR fat16, etc... Ok, I contact CHRV, thank.
VELESOFT
Postby KOE » 13 Feb 2010, 14:28
Забавная статистика.
Postby KOE » 04 Aug 2015, 10:08
ВНЕЗАПНО. По многочисленным просьбам трудящихся :)
1. Обновленное техническое описание (полное, со всеми схемами в векторном виде, можно увеличивать до усрачки и печатать хоть на А0)
2. Последняя версия прошивки
Если вкратце, то за последние годы было сделано почти все, что изначально планировалось. Жалко только, что времени ушло несколько более, чем ожидалось. Работы над встроенным ПО почти завершены, остался ряд мелких багов, требующий некоторого времени для устранения (не сделан tape in/tape out, возможно, не вывел признак read only на SD-карте, надо уточнить).
В 2015 году появился и даже как-то работает эмулятор ВГ93. Однако требует некоторого допиливания в плане соответствия таймингов реальному ВГ93 (пока не весь софт работает).
В связи с временным (надеюсь) выключением из работы Алонекодера, требуется сочувствующий человек, соображающий в TR-DOS и BDI и умеющий кодить на Z80 для допиливания. Возраст, пол, прочая хрень значения не имеют (хотя заявки от молодых гламурных дочерей олигархов рассматриваются в приоритетном порядке :) ). От сочувствующего требуется тестить новые прошивки, говорить, что не работает, что (и, желательно, как) исправить. Ну и регулярно пинать меня, т.к. я обычно пью пиво и ни хрена не делаю.
У меня еще осталась пара-тройка килограммов пустых печатных плат (как версии 2.666le, так и версии 2.2). Но распространять их мне ВНЕЗАПНО стало лень. Не будем вдаваться в подробности, спишем на то, что я сильно занят тем, что роняю спутники и пилю госбабло, соответственно, мне уже не до походов на почту. Если кому-то что-то надо, можно пересечься в Москве в рабочее время.
Про исходники прошивок/CAD-файлы. Пока доступны только участникам разработки. Есть вероятность, что после завершения работы над прошивками будут доступны всем, т.к. мне уже давно все пофиг.
Сайт поддержки, очевидно, в скором времени тоже обновится.
tfm.rar
(1.58 MB) Downloaded 1993 times
firmwarez.rar
(694.2 KB) Downloaded 1861 times
Postby lvd » 04 Aug 2015, 12:30
Аяяяй, в доку-то прям из пентевной копипасты массивные детекчу :)
Postby KOE » 07 Aug 2015, 18:18
Нужна помощь в тестинге вг93.
1. Посоветуйте самые нестандартные черезжопные программы, работающие с вг93 напрямую. Цель: убедиться, работают ли они у меня.
2. Хочу исходный код загрузчика ZX-Format #8. Желательно с комментариями.
Postby lvd » 07 Aug 2015, 20:34
Может отдельную тему или даже раздел форума замутить?
Users browsing this forum: No registered users and 24 guests
