RND LD H,'RND_TBL
LD A,0
INC A
LD (RND+3),A
LD L,A
LD B,(HL)
ADD A,55-24
LD L,A
LD C,(HL)
ADD A,24
LD L,A
LD A,B
ADD A,C
LD (HL),A
RET
CHRV wrote:LVD а ты на XOR и сдвиге не делал ГПСЧ? Классический
fk0 wrote:Для этого два генератора смешиваются с разными периодами. У maxim аппнота была.
/* vim: set foldmethod=marker foldmarker={{{,}}}: */
/* (C) Kirill Frolov (fk0.pp.ru) 2012 */
/* !\file random.c LFSR pseudo random generator,
* see: http://www.maxim-ic.com/app-notes/index.mvp/id/4400 */
#include <stdint.h>
//#include "random.h"
#include <stdlib.h>
#include <time.h>
#define PMASK32 0xB4BCD35C
#define PMASK31 0x7A5BC2E3
#ifndef PERSISTENT
#define PERSISTENT(v) v
#endif
PERSISTENT(static uint_fast32_t lfsr32);
PERSISTENT(static uint_fast32_t lfsr31);
static unsigned shift(uint_fast32_t *lfsr, uint_fast32_t mask, uint_fast8_t xor)
uint_fast8_t fb = (*lfsr ^ xor)&1;
*lfsr>>=1;
if (fb) *lfsr^=mask;
return *lfsr;
static unsigned rand_16(void)
shift(&lfsr32, PMASK32, 0);
return (shift(&lfsr32, PMASK32, 0) ^ shift(&lfsr31, PMASK31, 0)) & 0xffff;
unsigned long random_get(void)
return rand_16()<<16 | rand_16();
void random_feed(unsigned r)
do {
r=r*31153;
shift(&lfsr32, PMASK32, r>>8);
shift(&lfsr31, PMASK31, r>>9);
} while (lfsr31==0 || lfsr32==0); /* avoid zeroizing LFSR */
void random_init(void)
if (lfsr32==0) lfsr32=0xABCDE;
if (lfsr31==0) lfsr31=0x23456789;
#ifdef RANDOM_TEST
#include <stdio.h>
unsigned long govnonext=1;
long int govnorand(void) {
govnonext=govnonext*1103515245 + 12345;
return (unsigned int)(govnonext/65536)%32768;
int main()
random_init();
#if 0
n=65536; do {
random_feed(n);
printf("%lu\n", random_get()&0xffff);
printf("%lu\n", random_get()>>16);
} while (--n);
#else
srand(time(NULL));
random_feed(rand());
fputs("\033[?38h\033\014", stdout);
fflush(stdout);
putchar(034);
for (unsigned long i=0; i<200000; i++) {
unsigned x, y;
#ifdef RAND
x=1024.0*rand()/RAND_MAX;
y=760.0*rand()/RAND_MAX;
#elif defined(BADRAND)
x=rand()%1024;
y=rand()%760;
#elif defined(RANDOM)
x=1024.0*random()/RAND_MAX;
y=1024.0*random()/RAND_MAX;
#elif defined(LFSR)
x=random_get()%1024;
y=random_get()%760;
#elif defined(BADLFSR)
x=shift(&lfsr32, PMASK32, 0) % 1024;
y=shift(&lfsr32, PMASK32, 0) % 760;
#elif defined (GOVNO)
#if 0
static unsigned long A=1664525, C=1013904223, X=54353;
X=(X*A+C)^0xffffffff;
x=X%1024;
y=X%760;
#else
x=govnorand()%1024;
y=govnorand()%760;
#endif
#else
#error define BADRAND, RANDOM, LFSR, BSDLFSR or GOVNO
#endif
putchar(0x20 | (y>>5)), putchar(0x60 | (y&0x1f));
putchar(0x20 | (x>>5)), putchar(0x40 | (x&0x1f));
fputs("\033\003", stdout);
#endif
return 0;
#endif
fk0 wrote: Все методы дают нормальную последователность, кроме A*X+B mod M
random PUSH BC:LD A,(R1),C,A
LD A,(R2):ADD A,C:LD C,A
LD (R1),A,A,(R3)
SUB C:LD C,A,(R2),A
RRCA:LD (R3),A
LD A,C:POP BC
RET
R1 DB #15
R2 DB #70
R3 DB #FD Users browsing this forum: No registered users and 28 guests
